will carbon ap2 synchros go into an ap1 ?
Old Apr 20, 2011 | 06:32 PM
Slmd2K's Avatar
Default will carbon ap2 synchros go into an ap1 ?
Having trouble getting into 5th gear. and as of right now its pretty much locked and i cannot shift into 5th. ive been trying to search for the solution but ive been reading more and more that the brass synchros in the ap1 can wear out and even "burr". just curious if id be able to swap for the carbon ap2 synchros..
Old Apr 20, 2011 | 06:57 PM
TerminatioN's Avatar
Doubt its your synchros. Try changing your transmission fluid (I suggest synchromesh) and doing this:
Originally Posted by Billman250
I have fixed this in a few minutes. Its worth a shot. You have a burr on the gear cog.
Turn car off. Hold clutch down.
From 5th, you will need to try to force it fast into 6th.
once you can get it in 6th, row it from 5 to 6 about 50 times. This could lower the burr and cure it completely.
Source: https://www.s2ki.com/s2000/topic/845...#entry20218847
Solved my problem. You'll be no worse off if it doesn't work. Definitely worth a shot before you drop all the money on a rebuild.
Old Apr 20, 2011 | 07:47 PM
Slows2k's Avatar
AP1 service parts are carbon coated.
Old Apr 21, 2011 | 05:38 AM
AngryTurtle's Avatar
Even if they do it is probably cheaper to buy a used tranny.
Originally Posted by Slows2k
AP! service parts are carbon coated.
Shift key
Old Apr 21, 2011 | 06:22 AM
Importedpower's Avatar
+1 for Synchromesh and the gear change while parked
Old Apr 21, 2011 | 03:00 PM
Kyushin's Avatar
Banned
Buying a used Ap2 tranny will be significantly cheaper than trying to retrofit the AP2 synchros, IIRC you have to replace nearly all of the gear sets as well and they are insanely expensive that way.
Old Apr 21, 2011 | 04:22 PM
Slmd2K's Avatar
changed the fluid today no metal shavings or pieces came out... even stuck a rod and magnet in there and no flakes or anything. ive been trying this engine off gear change thing alot but no progress. i cannot engage into the gear at all, its just not having it. and your right about the ap1 service parts are all carbon coated.
Old Apr 21, 2011 | 04:41 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
So i talked to the guy who i gave that advice to this weekend. (rowing it into 5th/6th gear)
His trans is completely fixed.
Old Apr 21, 2011 | 04:45 PM
Slmd2K's Avatar
billman, when your 6th went out, was it like completely closed off or were you able to get it in just a bit?
Killin9's
Sep 28, 2012 07:36 PM
Snake_s2k
Oct 13, 2011 04:15 AM
TerminatioN
Feb 16, 2010 08:20 AM
kaissi
Apr 3, 2008 10:10 AM
