Window makes a grinding sound
Old Dec 22, 2012 | 12:08 AM
2SoonS2K's Avatar
Default Window makes a grinding sound
Hey guys, my passenger window makes a nasty grinding sound when i roll it down. I've noticed that after a car wash or if it rains, the window temporarily goes down smooth.
Can anyone give me any advice on how to fix this? I took apart the door panel to install speakers, but I couldn't really see much of the window.
Any help would be appreciated. Thanks
Old Dec 22, 2012 | 12:11 AM
S2KIrishman's Avatar
my windows do this too...you just need to regrease the track...ive been lazy and putting it off because theyre not exactly the easiest to get to
Old Dec 22, 2012 | 11:44 AM
2SoonS2K's Avatar
How do I get to the tracks? Is there a DIY?
Old Dec 23, 2012 | 11:47 AM
2SoonS2K's Avatar
bump
Old Dec 23, 2012 | 12:26 PM
MM3Kwolik's Avatar
Mine did it too and what it ended up being was the rubber weatherseal on the outside, as it gets older and stiffer it makes a horrific scraping/screeching sound against the glass. I just peeled it back with a screwdriver and greased up the whole thing with shin etsu grease and it's good as new. I too originally thought it was the track or something internal, which it clearly wasn't.
Old Dec 23, 2012 | 12:27 PM
MM3Kwolik's Avatar
It's the outer weather seal which is why after the rain or wash it goes down smooth, because of the moisture on the window. If it were the track, it would make the sound all the time regardless.
Old Dec 24, 2012 | 03:51 PM
2SoonS2K's Avatar
Thanks a lot! I'll go find some Shin-Etsu and give it a try.
jaboo008
Feb 14, 2015 05:48 AM
MyEeek
Jan 11, 2008 11:02 AM
dogzilla
Nov 8, 2007 06:02 AM
Sundance
Sep 11, 2004 07:08 AM
mingster
Nov 13, 2000 08:55 PM
