Wont Start after Gauge Install.
Old Jun 8, 2009 | 04:23 PM
deez_nutz's Avatar
Default Wont Start after Gauge Install.
buddies s2k wont start after installing a new set of pillar gauges. im guessing we shorted a wire. what do you guys think?
its got power just wont start.
its all stock and we were intalling a new a/f gauge. also a new oil pressure but didn't make it that far....
Old Jun 8, 2009 | 04:45 PM
ahrmike's Avatar
More info:
How does it not start? crank/no crank/ hesitates/doesnt catch at all/no power/what.
also, what did you guys mess around with while you guys were installing the gauges?
Old Jun 8, 2009 | 04:47 PM
Slows2k's Avatar
Either you need to unscrew it or it's completely unrelated. Time to undo whatever was installed 1st.
Old Jun 8, 2009 | 04:50 PM
deez_nutz's Avatar
he had gauges in previously, same ones, air/fuel and oil pressure...the original gauges worked fine.
the next gauge (autometer) never read the air/fuel but still powered up. when we went to start the car, everything worked and the starter worked, it just wouldn't fire.
Old Jun 8, 2009 | 07:02 PM
S2Kwikat9k's Avatar
A wire definitley shorted we just dont know what blew when the wire shorted, but the wire that shorted was attached to the ecu, is it possible to damage the ecu if you short out a wire that is directly connected to it
Old Jun 8, 2009 | 07:05 PM
Slows2k's Avatar
English. speak it.
Old Jun 8, 2009 | 07:59 PM
ahrmike's Avatar
^lol.
And yes, if you short something thats directly connected to the ECU, its the same as shorting out the ECU which can and will break.
Old Jun 9, 2009 | 05:30 AM
S2Kwikat9k's Avatar
whats with the english speak it? i was just trying to let you know we definitely shorted out a wire that was connected directly to the ecu. anyways so does this mean i need a new ecu?
Old Jun 9, 2009 | 07:43 AM
SLracer's Avatar
Unfortunatly I believe you do. I don't know about the S2k specifically but I know on other cars the ECU is real easy to blow by shorting a wire attached to it. I am not sure what the english comment was about, I thought it read just fine
Old Jun 9, 2009 | 09:15 AM
Slows2k's Avatar
Sorry, your post was is a giant run-on sentence.
If you use some capitol letters and punctuation your chances of a helpful reply will increase.
plAythiNG
Apr 13, 2016 01:11 PM
espelirS2K
Mar 19, 2006 02:22 PM
hmss2000
May 31, 2005 02:17 PM
jdmdohcpower
Apr 24, 2005 08:12 AM
Nick32
Apr 16, 2005 04:53 AM
