303 Cleaner and Spot Remover and fabric cleaner
I was going to pick up a cleaner but could not determine the difference between these two: http://www.autogeek.net/303552.html and http://www.autogeek.net/303cleanspot.html. Do you guys have any recommendations?
Spot remover is more than likely a more alkaline detergent, the other is probably more neutral.
Folex is a good neutral spotter with a bit of detergent in it. It is not a specific spotter.
If you are looking for an all around kit i strongly suggest following this:
[QUOTE]Pretest Spot-Removal Procedures And Products
In an inconspicuous area (under a sofa cushion, on an area of carpet under or behind a piece of furniture), apply several drops of solution on the article and rub gently with a clean, white towel. If color transfers to cloth or a color change occurs a professional cleaner should be consulted. Apply the solution again, wait 1/2 - 1 hour, if possible, and inspect for any damaging color changes.
Do not over wet. Use small amounts of the spotting products and blot frequently. Always blot, do not rub or brush. Work from outer edge of the spot towards the center to prevent rings.
Beginning with step 1, treat the stain area with each spotting solution until the stain is removed. It may not be necessary to complete the entire series of steps. The final step is always to rinse carefully the area with water, then absorb all the remaining moisture with absorbent towels.
Be patient. Some spots respond slowly. All spots and spills cannot be removed from every fabric due to differences in fibers, dyes, construction, finishes, composition of the spills, length of time the spot has remained on the article, etc. Some stains require professional treatment.
To find the right procedure and product for cleaning various stains, choose the type of stain from the list below and select it.
Stain List
Stain Type
Recommended Products
Blood
Stain List
Stain Type
Blood
