Big Blue Question?
I purchased Big Blue II about one month ago. After several uses I washed it for the first time last night. I put my washing machine settings on delicate, colors, non-permanent press, and warm-cold. Used a little bit of liquid Tide and let it hang to dry. Anyway, after washing my car today Big Blue didn't seem to be as absorbent. I had to ring it out several times and it didn't seem to perform as it had in the past.
Is this normal? How long of a life does Big Blue have? How often should I wash it? Did I do something wrong? Any thoughts or suggestions from fellow Big Blue owners? Thanks!
I wash mine after each use with other microfiber stuff. I use Tide powder with warm wash/cold rinse and no fabric softener. Does liquid tide have fabric softener in it? - Fabric softener can mess up absorbency, or so I've been lead to believe. I use the dryer set at delicate/very low heat. I've never had any problems.
At least for the fuzzy microfiber, I belive they last longer if you only wash them with other microfiber towels. At first I washed them with my cotton polishing cloths (in the process of being replaced by all microfiber). I found that the cotton cloths would end up sticking to the microfiber stuff - I think that might take some of the life out of the microfibers as well.
John
John
Is this normal? How long of a life does Big Blue have? How often should I wash it? Did I do something wrong? Any thoughts or suggestions from fellow Big Blue owners? Thanks!BTW, I washed them with liquid Tide, Cheer, All and Woolite ( I have to use liquids in my machine); it did not matter. I use no fabric softner.
I had purchased the big blue w/little blue from proper auto care. I wash the two of them together after every use, separartely from my other microfiber towels. I use very little detergent, and only use liquid detergent. I have read that regular detergent granules can become trapped inside the fibers and if they do not dissolve they can block the fibers and scratch your paint.
I have found that big blue and little blue dry even better now then they did the first time you have used them. I always make sure to wash them in cold water and dry them on a low setting not to melt the fibers.
The instructions say not to dry them, this may be part of your problem
I have washed mine many times and it's absorbancy seems the same but a few weeks ago it got accidentally dried and that first wash after it wasn't nearly as good, I believe it has gone about back to normal by now.
I use the California blade first and then use the Blue Towel, never have to wring it out.
