Clay Bar Rear Plastic Window?
Old Aug 13, 2007 | 06:20 AM
VilleS2K's Avatar
Default Clay Bar Rear Plastic Window?
I assume it's fine, but I just want to make sure I can clay my rear plastic window. I have a little bit of paint overspray from workers painting a building that is really irritating me and have not been able to completely get rid of it.
Also, I constantly seem to have a really thin film or haze on the inside of my windshield. I use armor all and meguiar's dash and leather products on the inside. Is this film the result of chemicals evaporating out of the protectant when the car sits in sunlight? It seems no matter what I clean the glass with, this film is always there .
My car is immaculate and these two issues are bugging me... thanks in advance for help.
Old Aug 13, 2007 | 06:54 AM
wanabmmaboy's Avatar
I did mine over the weekend. Encountered no issues.
Old Aug 13, 2007 | 07:52 AM
wanabe's Avatar
always go least aggressive first...
that would be plexus
then if you go clay, make sure its a good quality detailers clay- and test a small area first.
your glass issue can be evaporation of products- it can also be that the glass really was not completely clean... after cleaning it buff it with a dry mf towel.
trick- do the inside side to side and the outside up and down... then you can always tell what needs to be cleaned (from which direction the haze is)
Old Aug 13, 2007 | 09:44 AM
VilleS2K's Avatar
Thanks... I'll definitely try the up and down vs. side to side trick on the windshield.
Old Aug 13, 2007 | 11:35 AM
MikeyC's Avatar
I'd be REAL careful using clay on your plastic window. Clay is abrasive and could leave some nasty results on soft plastic if you're not careful. Make sure to use lots of lube if you're going to try it.
Old Aug 13, 2007 | 12:24 PM
wanabe's Avatar
good advice...
you never want to make a problem worse by detailing it
Old Aug 13, 2007 | 04:26 PM
MikeyC's Avatar
Originally Posted by wanabe,Aug 13 2007, 03:24 PM
good advice...
That's a lesson I've learned the hard way . . . a few times. I guess I'm a slow learner.
Old Aug 15, 2007 | 05:46 AM
fastgsx's Avatar
Most clay says not to use on clear plastics.
But i have seen it done with success...be very careful.
Old Aug 19, 2007 | 10:40 AM
BrandonS2K's Avatar
im just glade i exchanged my plastic softtop s2k within a week of purchase. well not because of the top but it had more major problem. well i went with the glass back top and couldnt be happier with it. i say it would be a good investment to go with the glass. makes the car look alot better and less of a pain to take care of. not to mention better visability...just my two cents
bgoetz
Oct 14, 2008 07:06 PM
jert534
Aug 13, 2006 02:31 PM
vodalus
May 14, 2006 08:19 PM
pcovers
Aug 26, 2001 06:21 PM
SiK182
Jun 15, 2001 08:22 PM
