Gum on leather seat...
Originally Posted by Sabre,Jan 15 2008, 01:41 PM
Might I also suggest laying a folded paper towel over the gum and then using an iron on low so you can put a little pressure on it WHILE heating it.
On low heat, with the paper towel between it and the leather, it should insulate it enough not to harm the leather, and the gum will start to stick to the paper towel.
Thanks for all the help W&W guys!
Originally Posted by 2002S2K,Jan 15 2008, 05:31 AM
While you are at it with the peanut butter, pull out a little wheat bread and a little grape jelly, make sure it is grape jelly because that is the only kind I like...make a sandwich and do this... j/k to tukluc, no harm intended
But I can guarantee that peanut butter is THE best way to get gum out of hair
with candy and gum in carpet and upholstery, I like to get a can of compressed air (duster). Turn the can upside down, and spray onto the gum. The liquid compressed gas will quickly freeze the gum, and easily chip off. As some of you are worried about getting water into the perforated leather, you can rest easy with this method, because the ice is not water-based. Follow up with a leather cleaner, for any remaining residue.
Mike9000
Sep 4, 2007 01:57 PM
Master Apex
Feb 15, 2001 08:51 PM
