How to clean speedo display?
If you can get Plexus that is amazing stuff, it helps to keep plastic and glass surfaces dust free, it doesn't attract dust statically. Polishes up super slick and smooth, I love the stuff, use it on my Mugen rear window as well, it is expensive but nothing compares IMO. Some typical vinyl cleaners can spot or stain the dash so I avoid them.
yes it is an aerosol, you can spray it on the part or on a cloth, wipe until the surface is clear and smooth, you know polishing action is done when the surface is super slick. A can will last you many years, despite the cost nothing works as well IMO, motorcycle guys swear by this and I use it on many surfaces with great results.
For tasks such as this I like to use the Novus Plastic Polish system. It comes in three different "strengths" that you can choose to work with depending on how bad the plastics are scratched (sort of like using sandpaper in finer and finer grit ratings to smooth something out, but in a liquid format). You can always start with the least intrusive formula to see how effective it is, but then can break out the more heavy duty stuff if needed. Works great on headlamp/brake light covers as well as the central brake light on the lip of the trunk as well.
Purge
Nov 12, 2001 09:32 PM
