my engine bay... tried something new
thxs... the stuff came in a 1 gallon container maguyers (how many times will i spell this wrong?) picked it up at a local body shop supply store.. $20.00 a gallon the only thing i found is that you need to spray a very fine mist (picked up an oil mister at my local wallmart)
Hey wanabe,
Thxs
the motor was pretty clean b4 i started (only 7k miles) so all i did was mist the engine bay and waited 1/2 hour nothing more. (no removal) If your engine bay is a bit dirty they do reccomend starting with Meguiars APC + (4 to 1 ratio)
At first i used an empty windex bottle but i came out very spotty
on some plastic (fuse cover etc) but when i switched to a very fine mist it came out great...
here's the link where i found the stuff
http://autopia.ws/forums/showthread.php?s=...&threadid=13432
http://autopia.ws/forums/showthread.php?s=...&threadid=14427
Good luck
Thxs
the motor was pretty clean b4 i started (only 7k miles) so all i did was mist the engine bay and waited 1/2 hour nothing more. (no removal) If your engine bay is a bit dirty they do reccomend starting with Meguiars APC + (4 to 1 ratio) At first i used an empty windex bottle but i came out very spotty
on some plastic (fuse cover etc) but when i switched to a very fine mist it came out great... here's the link where i found the stuff
Good luck
Here's a tip i learned from an fellow NSX owner.
Cleaners needed: Gunk Foamy Engine Brite and Foamy Armor All
Wait for the engine to cool down. Spray the engine with Gunk Foamy Engine Cleaner. Let it sit for 15 minutes. After that spray the engine down. Immediately after that use the foamy armor all for tires (DO NOT use the liquid armor all) and spray the complete engine bay. Start the car and let the engine run for 20 minutes WITH the hood shut. (At this time wash the exterior) after 20 minutes open the hook and...
Looks just like it came out of the factory.
That sounds great, but the only thing that worries me is using a hose in the engine compartment
Ive heard people who have done this and then not be able to start their car
Is there anything specific to hose? Anything that needs covering with a plastic bag etc?
