My ONR Process
Old Jul 20, 2009 | 09:01 AM
akimel's Avatar
Default My ONR Process
I have been experimenting with my ONR method for nine months. Here is the process I used last Saturday on my S2000:
1) 2 gals. of water, 2 ounces of ONR. We have hard water here in Roanoke County, so I go with the maximum prescribed amount. I only use one bucket, with grit guard.
2) I gently rinse one or more panels with ONR with a Lowe's Proline grout sponge. This effectively removes most of the dirt, and the grout sponge easily releases the dirt into the rinse bucket. The sponge is particularly helpful on the very lowest panels, which are typically the dirtiest.
3) I then go over the same panels again with ONR with a microfiber mitt. Because most of the dirt has already been picked up by the grout sponge, the mitt doesn't get as dirty when used exclusively, and I do like the feel of the mitt on the paint surface. I repeat as necessary.
4) When I believe that I have thoroughly cleaned the surface, I then begin to dry with either a waffleweave towel or a thick napped microfiber towel. As recommended by Scottwax, I use two towels.
5) With an ONR-dampened towel I wash the door and trunk jambs immediately after I have washed the door and trunk, respectively. I prefer doing this at this point rather than coming back to them. It makes sense to me.
6) When the entire vehicle has been washed and dried, I then wipe down hoses, coverings, and painted surfaces in the engine bay with an ONR-dampened towel.
7) With the same ONR-dampened towel, I wipe off the exhaust tips.
8) Finally, I wash the tires and wheels with the remaining ONR rinse, using the appropriate brushes. With my wheels I find that I need to also use a dampened towel to remove all the brake dust and dirt. I then dry the tire and wheel.
The glaring weakness in this method is the failure to properly attend to the wheel wells and rim barrels. I haven't found a brush yet that is narrow enough to slide easily between the narrow space between fender and wheel on my S2000 (the CR-V is, of course a different story), and while I do wash the barrels with my spoke brush, I haven't figured out a way to effectively wipe off and dry the barrels. It's easier to clean tires and wheels the old fashioned way, I think (i.e., with a hose). On the suggestion of a fellow at AutoGeek, I may try a sponge next time on the fender wells.
I welcome all suggestions, criticisms, and tips.
Cheers,
Al
Old Jul 20, 2009 | 02:50 PM
shotgunjimmy's Avatar
i recently picked up a garden pump sprayer from amazon, http://www.amazon.com/gp/product/B000CSYLD...x_ya_oh_product to use when i ONR the car. i didnt like the way the wheels looked when using ONR on them, so i use P21s wheel gel with the garden sprayer and it works well. it might be a pain in the butt, but after washing the wheels, you could empty the garden sprayer and just pressurize the air inside to blow dry the wheels. ive never tried it but i dont see why it wouldnt work. i also use the sprayer on the convert top so i can give it a good rinsing before applying raggtop.
Old Jul 22, 2009 | 07:34 AM
wanabe's Avatar
with our water shortages in calif, its just a matter of time before i will have to try out this stuff...
good post !!
Old Jul 22, 2009 | 09:38 AM
espelirS2K's Avatar
Please use two buckets. You'll have a greater chance of introducing marring with only one bucket. I have a pic lying around of what it looked like using two buckets.. let me dig it up.
Old Jul 22, 2009 | 09:42 AM
espelirS2K's Avatar
Found it! You can tell how dirty the car is (fender done, door not):
And after half a car with the two buckets:
Even though the buckets are dark and red, you can clearly see the difference between the "rinse" bucket, and the ONR bucket. (if you can't-- ONR bucket on the left, "rinse" on the right)
Old Jul 22, 2009 | 10:04 AM
aznives3's Avatar
how dirty are the cars when you guys are doing your ONR process? to me, rain water spots=dirty, but some guys were saying in the thread i posted earlier just do do a QD spray and wipe, but i dont mind doing ONR wash as well. So how dirty are we talking here when you are doing an ONR wash?
Old Jul 22, 2009 | 10:23 AM
espelirS2K's Avatar
Dirty, like haven't been washed in a week or two (sometimes more)
DTMAUTOBODY
Aug 10, 2013 05:55 AM
The Twanksta
Dec 24, 2008 01:22 PM
DaveFromSydney
79
Nov 28, 2004 01:03 PM
SolReborn
Oct 20, 2004 01:20 PM
Clayman
Mar 26, 2004 05:12 PM
