Need Something A LITTLE more Aggressive
Old Mar 24, 2008 | 05:41 PM
slanguage's Avatar
Default Need Something A LITTLE more Aggressive
I am looking for a compound/polish a little more aggressive than Poorboy's SSR 3. I have some water spots in the paint, and ssr3 does get most, but I need something a tad bit more aggressive. Any suggestions?
I have a PC, and foamed wool pad, yellow, orange and white pads for it.
T.I.A.
Roger
Old Mar 24, 2008 | 07:37 PM
GPWhiteS2kFTW's Avatar
Duuno man, I am sure someone will chime in shortly...
Old Mar 24, 2008 | 08:30 PM
wanabe's Avatar
roger- what pad have you been using with the 3?
its not a polish, its a compound (pretty aggressive) and it should do the trick-
are your water spots etched? (can you catch an edge of the spot with your fingernail?)- if so, its not an easy fix. you have to cut off the edges of the spot and wont be able to really remove it.
if its not etched, you should be able to get out the stain.
are you fully working the product til it dusts?
your paint should look pretty bad afterwards if you are doing it right... once the problems are cured, a polish is the cure for the compound haze.
Old Mar 24, 2008 | 09:20 PM
GranPrix's Avatar
its not a polish, its a compound (pretty aggressive) and it should do the trick-...
You should be using the Lake Country CCS orange pad.
Old Mar 25, 2008 | 03:49 AM
slanguage's Avatar
I started with the CCS yellow and worked my way up. The surface feels smooth to me, but I will double-check later today, and get back to you guys!!
Old Mar 25, 2008 | 04:09 AM
Ubetit's Avatar
[QUOTE=wanabe,Mar 25 2008, 12:30 AM]
Old Mar 25, 2008 | 07:19 AM
wanabe's Avatar
o.k.- got a pm asking for products with less dust than poorboys...
related to this so i will put this here- i would first go to the menzerna line of polishes.
and its all opinion, so we might get some others here too-
Old Mar 25, 2008 | 05:03 PM
whykit's Avatar
i want to know this too...
Old Mar 25, 2008 | 06:57 PM
qsmarcei's Avatar
I've got water spots that are very deep as well. I just remove the swirls and ignore them. I cant catch them with a finger nail, but I lack a paint gauge to really feel confident in trying to polish them out. I did two passes with IP and an orange pad. That's as far as I will go without further instruction.
Old Mar 25, 2008 | 08:12 PM
sevenrd's Avatar
In regard to the question about a polish with less dusting than PB's, you may want to try the Optimum line (polish, hyper-compound, compound). Almost zero dusting and effective.
Neuman04
Apr 30, 2010 12:54 PM
S2KRAY
May 7, 2009 05:49 PM
dmw16
Jun 18, 2007 08:08 AM
flitcroft
Mar 14, 2005 09:28 AM
03s2kman
Aug 17, 2004 07:31 AM
