paint restoration
Do you have swirl marks and dull paint you want to correct? if so, you'll need to invest in a machine (porter cable 7424xp is best entry level) and theres many different combinations of polish and sealant/wax you can use.
these are general how-to vids that can point you in the right direction of restoring your S to where you'd like it to be
http://www.moddedmustangs.com/forums...ow-videos.html
you will want to
1 wash
2 clay
3 compound if necessary
4 polish
5 wax or seal
You want to pick up a Griot's Orbital Polisher for the job.
For a compound and polish you can use
Meg's DA300 with DA Cutting Pads
finish with Menzerna SF4000 with an Uber Green Pad
then protect with 1Z einszett Glanz Wax or the like
1 wash
2 clay
4 polish
5 wax or seal
Also check out some of the articles listed here: Internet Resources for Detailing. I've had good luck using Meguiar's Ultimate Compound, followed by M205. I haven't tried Ultimate Polish, which is designed to be a follow-up to Ultimate Compound. Both Ultimate Compound and Ultimate Polish are available at local auto stores.
One important tip: always do a test spot before polishing out the car! You want to make sure that you can make a 12x12 spot look great before polishing the rest of the vehicle. This tip will save you lots and lots of aggravation, as well as time and energy.
