polishing kits
It really depends what your budget is for the polishing kit. Autogeek puts together lots of different packages and obsessed garage offers offers a nice package as well if your budget allows. There are tons of options out there, it is an investment but picking up a good polisher like a rupes is worth it if you want to get into the polishing world. I have never used the torq but I think it's a good entry option for polishing if you do not want to pay for top tier polisher. You can get good results with just about any polisher out there if you have good technique.
Looking for a polisher that I can sand with also,when I repaint front bumper,may do the whole car next year also.
gather a dual orbit polisher would do both ?
Watched lots of How too"s on autogeek last night,thanks for the heads up
Ps in uk so many not available here.
21mm is that pad size,not sure regarding that measurement
I see a rupes 3" and that's 75mm ish on the above site.?
21mm I'm referring to is the orbit size. The larger the orbit typically the quicker the correction but with sanding I would be afraid it would remove too much too quickly. The pad size either 3" or 5" just depends on what area you're working on. You could do everything with a 3" pad if you wanted just take longer in the larger open areas than a 5" pad to cover the entire surface area.
