Poorboy's Residue
Old Aug 7, 2007 | 08:06 AM
02SuzS2k's Avatar
Default Poorboy's Residue
Anybody here had issues with Poorboy's SSR2.5 leaving behind a "pitting" type residue on your car's finish? It almost looks like minor rock chips. I haven't tried claying it off yet, but thought that might do the trick.
Old Aug 7, 2007 | 08:57 AM
GTScott's Avatar
I have used 2.5 for a while and never had that issue. From your description, it sounds like dust that is getting left behind and is then adhering to your finish. What I would do to be sure that all of the dust is removed is, after you polish, take a QD (Spray & Wipe, Spray & Gloss, whatever you use) and wipe down the car to get ALL of the dust off. Another option is to re-wash but that can be a bit more time consuming.
If you don't think what you are getting is from polishing dust settling, describe it some more and I will take a crack at it.
Old Aug 7, 2007 | 09:05 AM
02SuzS2k's Avatar
You're probably right. I did notice a whole lot of dusting when I was polishing and I wiped the area down, but only with a MF towel. Thanx for the input. You think clay would get it off, or maybe polishing/waxing again.
Old Aug 7, 2007 | 09:59 AM
GTScott's Avatar
While clay would work in almost any situation with the dust, I would first try a good soapy wash and see if that gets it. If it has baked in, it may take the clay.
Another issue, not so much on the S but on a lot of other cars, is to be careful with the dust on black plastic trim and cowels - especially textured plastic. If it sits too long it can be a real pain to scrub off. When doing a full polish, I typically mask the trim. It takes a long time but then again, so does a good, full polish.
Old Aug 7, 2007 | 10:35 AM
Ubetit's Avatar
With some car's I do i notice fine little pitting in the clear coat but they come to me that way. I've seen a hood of an S2000 like that and my fender has a little area too.
Apparently some guys have a problem with 2.5 over on Autopia.
Old Aug 7, 2007 | 12:10 PM
s98d7fs's Avatar
Could be product spatter from the pad onto finished areas of the paint. It ends up looking like small flecks of <insert color of polish here>. It can be cleaned up with a wash or QD as folks have already suggested.
Old Aug 10, 2007 | 07:26 PM
globallyoff's Avatar
Maybe try using less product as well.
K
Old Aug 11, 2007 | 01:31 AM
RACER's Avatar
That kinda defeats polishing in the first place
Old Aug 11, 2007 | 11:04 AM
MikeyC's Avatar
I've used SSR2.5 in the past. It's a nice polish, but it dusts quite a bit IME.
I think what you're experiencing is most likely dried on polish spots. Try wiping them off with some QD and if that doesn't work try clay.
If it is actually pitting then it was likely there before you polished. I've polished cars in the past and once the paint is swirl free other imperfections become more noticeable.
Old Aug 11, 2007 | 02:23 PM
RACER's Avatar
[QUOTE=MikeyC,Aug 11 2007, 12:04 PM]I think what you're experiencing is most likely dried on polish spots.
tehsu
Jan 2, 2013 08:38 PM
wanabe
Oct 15, 2007 09:22 PM
guardiase
Dec 16, 2006 07:20 PM
jert534
Aug 25, 2006 12:56 PM
DVSwetwilly
Jul 30, 2004 08:10 AM
