Random orbit polisher question
Old May 5, 2008 | 10:34 AM
Spoon Fed's Avatar
Default Random orbit polisher question
What do you guys use to clean the wax filled foam applicators of your random orbit polishers? The fact that it is wax simple water wont 'cut' it. I was thinking Dish soap? I dunno.
Thanks
Chris
Old May 5, 2008 | 11:18 AM
Sabre's Avatar
The first set of pads I ever ordered was from Autogeek.net. I got their kit which came with their XMT Pad Cleaner spray that works incredibly well.
Old May 5, 2008 | 11:34 AM
tekstar's Avatar
I first soak my pads in an all purpose cleaner/water mixture. I then put the pads on the PC and spin them at speed 3-4 and use a pad brush to clean them off. Got all of my products from detailersdomain.com
Old May 5, 2008 | 11:43 AM
slanguage's Avatar
http://www.autogeek.net/dp730.html
This is what I use. works great. after i use this, I rinse the pads in warm water, then let the air dry, with the backing of the pad facing up.
Tat is important, so all the moisture does cause the glue to loosen and seperate the backing from the pad!!
Old May 5, 2008 | 01:23 PM
wanabe's Avatar
and spinning them on low speed is a great way to dry them...
but keep the speed down- from personal experience, if the speed gets too high the pad just flies apart!!
it was fun watching it happen, but it really does just pull itself apart--
i keep mine at the lowest speed- "1" for the dry process
Old May 5, 2008 | 01:32 PM
tekstar's Avatar
ahh i knew to keep the speed low but i didn't think 3 would be too high!
i'll be sure to keep it down next time hehe
Old May 5, 2008 | 02:17 PM
rodzilla's Avatar
I used "Snappy Clean" from I got from CMA. Just pour the powder in regular water, soak pads, squeeze, rinse, dry. My pads look and feel like new.
SpacemanBrent
Mar 23, 2012 04:34 PM
RedCelica
May 2, 2011 08:24 AM
demade
Jan 1, 2008 07:17 AM
SC2000
May 13, 2007 03:58 AM
imdarkrider
Apr 8, 2007 11:45 AM
