Rear ''Plastic'' window 00 s2k
#21
Hey guys, just to let you a little update. I received the Novus Polish... I did't do a perfect job...
It helped for sure, but I was expecting a better result... I bought some Past X at canadien tire yesterday.. I will try that tomorow.
Do you have other sugestions ? And I have a small scratch in my passenger window... How could i remove that ?
Thanks alot again !
Thanks alot again !
#23
Try the novus with the porter cable and a white pad if you have one. works beter that way.
You could try the plast-x on the glass, but this is something I have never done. Just make sure that the glass doesn't get too hot.
#25
THis subject brought to mind an experience I had many years ago with a Corvette. I uncareingly used a greasy rag to wipe the snow off my rear window. This ruined the window and thought it might be appropiate here to warn everyone to keep all petrolium products safely away. I would only use water based products in any attempt to clear. If a petrolium based product is suggested, I would want to see the results first on someone elses car.
#28
nureulwihaesuh
08-17-2005 06:58 PM
