Removing S2000 fender emblems?
Old Apr 24, 2006 | 06:28 PM
GPW03's Avatar
Default Removing S2000 fender emblems?
Hey gang,
I've decided I want to remove the s2000 fender emblems for a cleaner look. Im wondering what might be the best way to do so without damaging the paint?
Old Apr 24, 2006 | 07:02 PM
wanabe's Avatar
Originally Posted by GPW03,Apr 24 2006, 06:28 PM
Hey gang,
wd-40 is a good solvent... soak the area well- then use dental floss to lossen. the emblems come off pretty easy compared to the badges on the front and rear!
i replaced mine with black chromes... and replaced the badges with ricks thats how i know!!!
btw- a tip for you: be sure to tape the area where the badges are before removing them if you will replace them cause its very hard to do by the "measuring method"!
black chromes
Old Apr 24, 2006 | 07:30 PM
darkknight1999's Avatar
Before you just use the dentel floss, you should heat up the emblems with a hair dryer. Once you've heated it up then use the dentel floss to cut through the mounting tape to remove the emblem. If you can try and work the dentel floss behind the tape so its between the fender and the tape. You may need to reheat it a few times. Please make sure you don't burn your paint. You just want to heat it up not melt it
Once you get the emblem off the car you can use the WD-40 to remove the rest of the adhesive from the fender. Once this is done I highly suggest you wash the fenders with 'Dawn' soap or the like to remove the WD-40 from the paint. Then you should wax it
Old Apr 24, 2006 | 09:14 PM
mc2's Avatar
mc2
If you want to sell your emblems i'll buy them.
Old Apr 26, 2006 | 11:35 AM
secret2k-wrx's Avatar
I removed mine last year and it's a pain. Be patient and use lot of heat from the blow dryer.
1) I suggest you clean the car around the emblem.
2) Heat up the small area on the edge of the emblem (Work in small sections of 1" X 1" each) with a blow dryer and use the floss to cut the adhesive. If you have a thin strong fishing line, that would be better.
3) repeat until the emblem is completely off the car.
Now take a break because you are only third of the way done.
Now soak the left over adhesive with the WD40 or an adhesive remover. Using a soft cloth, remove the excess adhesive. Repeat until most of it is gone. Finally use your thumb to remove the rest with more heat from your blow dryer. NOTE: DO NOT USE ANY HEAT SOURCE WHEN USING WD 40. WD IS FLAMMABLE.
I think it is best done during a really hot day. Good luck.
Old Apr 26, 2006 | 02:16 PM
GPW03's Avatar
Thanks to all for their help. I didn't think it would be that much trouble to remove. I'll be sure to follow the tips provided.
Thanks again guys.
Old May 11, 2006 | 08:03 PM
iamhomin's Avatar
It seriously is a PITA. I took one side off, then worked on the other side the next day.
Just make sure you heat the adhesive well, because the paint can come off with the adhesive if you force it off.
Old May 12, 2006 | 06:25 AM
Umm.... you would have to do something just crazy to take the paint off. I'm not sure how you went about this but it only takes a few minutes to do it. If done properly is shouldn't be a PITA.
Old May 12, 2006 | 07:49 AM
MikeyC's Avatar
Were you pulling on the emblems? If you use the dental floss to saw off the emblems paint removal shouldn't be an issue.
Old May 12, 2006 | 11:06 AM
Avionics86's Avatar
Just have a deer run out in front of your car and hit it. When they replace your fenders just tell then to leave off the emblems. Worked for me.
SupeR_DavE
May 30, 2008 08:22 PM
tp-ap1
Jun 21, 2007 12:25 PM
nsxinsac
Nov 17, 2005 07:31 PM
tenaciousFD
Oct 24, 2005 03:02 PM
s2k_9000rpm
May 24, 2004 05:09 PM
