Sealant Removal
Old Mar 24, 2006 | 02:25 PM
Avionics86's Avatar
Default Sealant Removal
Does anyone know what I can use to remove the black sealant used to keep the headlights together.
Thanks
Old Mar 24, 2006 | 03:40 PM
xviper's Avatar
Are you actually trying to "remove" it or just take the light housing apart. To remove it, you would use a razor blade to get the bulk of it off and then use a solvent to clean the rest of it off.
If you are trying open it up to clear the amber things out, you need to bake the unit in the oven. You don't remove the sealant.
CAUTION! You better read this entirely before making such an attempt:
http://www.ricks2k.com/info/instructions/diffuser.pdf
Old Mar 24, 2006 | 07:48 PM
Avionics86's Avatar
Sorry for not being clearer. The car is going in for a total repaint. I already have the headlight and taillight assembly apart. I am going to paint the black plastic part in the headlight silver to match the car and will be installing clear diffusers. I figured while I was at it I would do the same to the taillights. I would like to remove the black sealant from the taillights and assemble it with a clear silicone.
Thanks
Old Mar 24, 2006 | 08:33 PM
xviper's Avatar
I see. Try the first method I posted about. Dry silicone should peel off plastic, but sometimes can be stubborn. I can't say exactly what kind of solvent you can use to get the residue off. Just be careful it won't dissolve the plastic of the headlight housing. Don't use any acetone, xylene or toluene base chemicals. Since silicone uses acetic acid (vinegar) as a manufacturing agent, try it on a part that isn't the lens to make sure it's safe.
Jinderv
Jul 5, 2013 10:14 AM
XclusiveAutosports
Jun 1, 2006 04:32 PM
XclusiveAutosports
Jun 1, 2006 08:50 AM
Red Rider S2K
Jul 7, 2005 07:44 AM
JiggaTaOG
Apr 21, 2001 02:00 PM
