Shinetsu Application
Hey everyone,
I was wondering if someone could tell me where exactly I am supposed to apply the grease onto? Pics would be a great aid, but a good description would suffice...
thanks!
thanks!
So I applied a layer of Shinetsu after my last wash. I applied the stuff, waited a few hours, and wiped the excess with a clean cotton rag. That was several weeks ago. Though the rubber seals appear dry (no excess), I am constantly wiping off a blurry grease mark from the tops of my side windows. Everytime I roll them down and up, I gain a little more grease. Am I missing something?
apply and rub in well- let sit then wipe off excess.
probably better to have too much than not enough! your rubber is likely in good shape.
you could take a clean rag and rub the seals down again (especially where you see it coming from)- use a light pressure to push out the excess that is in the surface pores.
and report back!!
Originally Posted by wanabe,Mar 2 2006, 10:33 AM
all over the soft rubber around the top seals...
Originally Posted by johnny,Mar 2 2006, 04:41 PM
so around the windshield frame AND along the bottom side of the soft top?
For a REALLY good time, Shinetsu your steering wheel!
When I applied it, I literally opened the top halfway, quickly applied it, closed the top and propped it up (with a sponge resting on the windshield top) like 1/2 an inch above the windshield so it could 'dry'.
Which brings to mind a silly question. How do YOU apply Shinetsu? Top completely down? Top up? Somewhere's in the middle? I can't imagine leaving the top halfway up/down is good for the top mechanism, but I also don't think stalling it in that middle is overly harmful if done for a short amount of time (5-10mins tops).
imo, no problem having the top part way up- btw, easier to clean the plastic rear windows this way too... i clean the window with the top part up so i can get back there- then put it all the way up to do a finish buffing.
on converts with fabric tops (like my wife's bmw), i begin to put the top down- but only part way while i cover the car (with old sheets- cause the top preservatives are spray cans, like raggtopp's)- then put the top back up. same idea for the top if you want to do the rubber parts with the top not up (which i agree with).
should be no harm with the top part way up - as long as no one grabs onto it with any force, and you dont go driving around like that!
