Stain / weird mark on paint, please help!
Old Oct 31, 2004 | 08:34 AM
s2hardtop's Avatar
Default Stain / weird mark on paint, please help!
The hardtop has a terrible stain. About 1.5" long * 0.5" Looks kind of like goo or some kind of paint-like thing that dripped on there. I tried using soap and water, and then Dawn, as someone recommended, but it didn't do anything. How can I get this off?
Is goo gone safe? Any recommended products & methods?
FYI, it's the Silver color, and it's on the hardtop. I don't know if the hardtop is metal or plastic, or if it even matters.
Sorry for the poor image quality, it's difficult to take a good picture of this mark.
Old Oct 31, 2004 | 10:15 AM
wanabe's Avatar
goo gone is a citrus based cleaner and is fine for your painted areas (dont get it on other surfaces, especially decals or badges)...
other solutions might be clay
polish
be sure to follow with a rewax of the area cause you will be removing all protection when you clean this
Old Nov 1, 2004 | 03:00 PM
s2hardtop's Avatar
I used a light polish and this didn't work. Oh no! What can I do now?
It's really on there - almost like paint but I don't think it's paint. Please help!
Old Nov 1, 2004 | 03:08 PM
wanabe's Avatar
if you really worked the polish (not just rubbed it on and wiped it off) then you do need another solution...
clay should get it too, but if polish didnt work clay might not either.
next step is a more aggressive polish- fine cut is next.
report back after you really work the area with a fine cut!
Old Nov 1, 2004 | 03:16 PM
s2ksimon's Avatar
if an FCC does not work, wet sannd may be the only option
Old Nov 3, 2004 | 12:44 PM
MYSSS2k's Avatar
if it's something gooey...you should get some wax and grease from a paint shop then rub it out. After you wax and grease you have to follow it up with glass cleaner so it doesn't damage your paint. AND Then you wax it or if there's stratches...use rubbing compound, and then wax.
Old Nov 3, 2004 | 12:51 PM
MYSSS2k's Avatar
wax and grease is also "tar remover" Just lemme know if it works, where are you located? I'm a detailer and that's what we use to get off excess paint or tar or stratches.
zeroptzero
Nov 4, 2012 07:24 PM
jamo9000
Jul 14, 2008 01:53 PM
cocogirl
Mar 21, 2005 07:24 PM
Gasroth
Nov 25, 2004 07:03 PM
secretvampire
Nov 29, 2002 09:01 PM
