This stuff works.....
got any pics??
or details of how you used it?
more product info at:
http://www.meguiars.com/?clear-plastic-car...-Cleaner-Polish
I taped off the area around my headlights, put a coat on with a microfiber pad 4", then used a buffer with a microfiber bonnet to buff it off. I did this twice to each headlight. I does remove oxidation. My headlights are probably worse then some, so some other people will have awesome results.
This is a pic of my driver's side headlight before I used this product. I will post an after pics within the next day or two
I have been using this stuff on my rear window. The window and top are not in that great of shape but, it helped alot!
I will give it a try when my headlights get to a stage where it needs a good cleaning. Mine are pretty much brand new.
I love meguiar's stuff. But I have personally used the Plastx and also used 3m rubbing compound and the 3m is a much better product. It can be found at Wal-Mart, Meijers, Autozone, ect... Hope this helps.
if you combine that stuff with a PC and a small polishing foam pad (i used griots orange) that thing will make your lights crystal clear!
I have used it on a 95 Suburban the lights were yellow and very very foggy... slap some 3M rubbing, orange pad, and set the speed to 5.... 2 hrs later they are about 90% new.... rock chips are still there but now i can see the bulb.
super-S2
15
Jul 8, 2003 11:38 PM
