Window cleaning
Was thinking about trying the Autoglym window polish has anyone used this? Or is there another product out their that should work just as good? I usually just use Stoners after washing my car or cleaning my windows if thet get bug splatter while it does a good job of providing a clean window it does not remove all those nasty water spots.
yes, any polish will work... to make your glass invisible again.
i suggest not working it as aggressively as on the paint.
i would first use vinegar for the water spots. can use it with your pc if you are careful not to use too much and keep the speed low.
my first choice for water spots is vinegar and on glass i like to follow that with a glass polish. but you can use any light polish (like a swirl remover or paint cleaner) if you go slowly and test an area first.
I might add that, although it doesn't really take out nasty spots, if I'm applying Klasse AIO to a vehicle, I hit all the windows with the PC and AIO. It cleans them nicely, will take out less-stubborn water marks and puts a nice protective (although not particularly long-lasting) coating on them.
