Window Scratch
Hey guys, so I just got back from a trip last night and took a look at the S this morning. Upon inspection I noticed quite a few somewhat "deep" scratches the top portion of my passenger side glass window-- looks as if a razor blade was taken up to it or something. I've searched through the forums but there seem to only be topics on the rear window getting scratched so I don't know what to make of this. So.. what do you guys think caused the scratch and are there anyways to repair it? Thanks!
edit; it's an MY02 if that helps at all
kinda hard to tell, but you might be able to get that out, or at least improve it with glass polish...
zaino makes one and there are several out there-
can try by hand, but i would use the p.c.
keep the speed down at first, test a small area and if all goes well, then go for it.
btw, before you put the window down, check the felt area at the bottom of the window for sand or other debris. if you cant feel any, lower the window slowly and then carefully feel with your finger inside the window track.
