San Diego S2000 Owners San Diego and Imperial County S2000 Owners Community meets, events and discussions.
Diff Swap
Old Jun 23, 2012 | 07:12 PM
RS2KFTW's Avatar
Default Diff Swap
Hey guys , So found out it was my diff not my secondary shaft bearing . I have a 00' AP1 and was wondering what I would need to put a AP2 Diff .Thanks!
Old Jun 23, 2012 | 07:16 PM
Carbon Blue's Avatar
I believe you will need to swap your existing ap1 flange onto the ap2 diff, but dont quote me on that. I think that may be for the tranny swap though.
Old Jun 23, 2012 | 07:23 PM
RS2KFTW's Avatar
Is that the flange coming off the driveshaft plugging into the diff?
Old Jun 23, 2012 | 07:59 PM
bradskee's Avatar
Alright so having done this a billion times (I need a new hobby) to swap diffs you need to swap the companion flange on the diff because the drive shaft bolts on the ap2 are bigger.
Sounds simple but it's not of you want to do it right. Can you just pull the but off and swap? Yes. But you're risking changing the Pinion depth and blowing the diff. Best advice I can give is either a) buy an ap1 diff b) buy and ap2 diff and have it reassembled correctly or c) just swap the flange and cross your fingers
Old Jun 24, 2012 | 01:21 AM
RS2KFTW's Avatar
@bradskee cool thanks! so let me break this down , if I go AP1 diff its a simple hitch and go . If I switch to the AP2 diff I have to rip off the flange from my AP1 diff and put it onto the AP2 diff , and hope that it wont blow again ? I would also need to get a new crush washer as well?
Old Jun 24, 2012 | 09:06 PM
bradskee's Avatar
Exactly
Old Jun 25, 2012 | 04:21 PM
TurboViper's Avatar
If you swap the flange and don't re-set the load on the pinion correctly and technically replace the crush sleeve the diff will fail again. Best bet is to grab yourself an AP1 diff or have someone professionally swap the flange, which would cost about the same as rebuilding your current diff.
Goodluck!
-Gavin
Old Jun 27, 2012 | 08:43 AM
RS2KFTW's Avatar
@bradskee @turboviper Cool , thanks guys! I had a shop professionally swap the flanges , everything runs fine but I need Diff mount replacements now.
WarrenW
Jun 9, 2017 03:58 AM
eg2solsi500
May 1, 2011 08:12 AM
franks2k
Jan 22, 2009 10:43 AM
cloud_9
Apr 5, 2008 05:40 PM
CHOWBOX
May 9, 2007 06:34 PM
