San Diego S2000 Owners San Diego and Imperial County S2000 Owners Community meets, events and discussions.
Turbo setup in SD
Old Sep 10, 2006 | 09:09 PM
R.P.M's Avatar
Originally Posted by Fusion_Saleen,Sep 10 2006, 03:23 PM
Mike there is a fix for the water temp now so you can run AEM EMS and use the temp in the dash. I'll try to find the link for you
modifry.com ok found it
Oh yeah, I forgot about that.
Old Sep 10, 2006 | 09:11 PM
R.P.M's Avatar
[QUOTE=ShMooveS2k,Sep 10 2006, 05:03 PM] i would most definatley would like to learn how to install this when i return.
Old Sep 11, 2006 | 08:04 PM
Liemoanh's Avatar
Installing a turbo is pretty straight forward.
Remove OEM header and replace with turbo manifold/turbo.
Install downpipe and exhaust.
Install front mount intercooler.
Connect all intercooler piping from turbo to intake manifold.
Remove oil pan and install oil return fitting.
Connect vaccum lines to BOV and Wastegate.
Connect oil feed and return lines to and from turbo.
Relocate oil filter.
Install 650cc + fuel injectors.
Install in tank fuel pump.
Install AEM EMS.
Get tuned by Church Automotive and have fun with peak tq # around 3500 rpms.
I'm still waiting for Mike to get tuned. I got alittle something for him.
Old Sep 11, 2006 | 08:45 PM
ShMooveS2k's Avatar
what about my exhaust do i just take it to the muffler shop i have hks hi power duals i would like to keep the mufflers. but do i get the exhaust changed b4 or after the installation
Old Sep 11, 2006 | 09:15 PM
Liemoanh's Avatar
Depends if they supply a midpipe in the turbo kit.
When I had the LoveFab turbo kit, I had Cody fab me up a midpipe that connected from the downpipe to my stock exhaust. I was running the Invidia exhaust at the time so it bolted up just fine. Since all aftermarket N/A exhausts bolts up to your catalyic converter (midpipe), you should be good to go.
The difference will most likely be the diameter of the downpipe. Optimal performance is gained by 3'+ especially on turbos. If you have a 3' downpipe that's clamped on to a 2.25' exhaust, your causing restriction, thus haunting performance. I choose to keep my 2.50' Invidia because I didn't want anymore power. My powerband was perfect for my liking. Full TQ at 3,200 rpms that stayed pretty flat tell redline, with a peak of 328rwhp at 8 psi.
Bottom line, if you want to keep your HKS, have the turbo kit supplier or muffler shop fabricate you a midpipe that will join the join downpipe to your HKS exhaust. If in fact the supplied downpipe bolts up to your stock cataylic converter (midpipe). You'll have nothing to worry about. Just call the turbo kit supplier for a definite answer.
BTW, what do you want to accomplish with the turbo kit? Will you be tracking, autoxing, drag racing, street racing or do you just want it for the fame? Just curious so no need to answer.
Old Sep 12, 2006 | 02:21 PM
ShMooveS2k's Avatar
what i would like to acomblish is to have that avaiable power on tap, yea some people would think well get a muscle car but its just not the same ya know? i would like to track the car occasionaly but i still would like it to be under the daily driver catagory but with balls. the S is one of my favorite driving experiances
Old Sep 20, 2006 | 07:42 PM
700+s2000's Avatar
Listen to mike he is a great guy. I also have a turbo setup and have gained some connections in San Diego. If you have any questions feel free to pm me and ill try and get you stuff at my sponsored price.
Nick
Old Sep 22, 2006 | 10:13 AM
ShMooveS2k's Avatar
awsome info guys well ill be deploying in two weeks but ill keep contact with you guys while im out there for more info. i plan to start to order some stuff mid deployment when ill have the funds.
Miahjera04
Nov 17, 2014 08:18 PM
Hicktown s2k
May 22, 2014 10:18 AM
GyozA
Nov 26, 2006 06:58 PM
skyteg
Nov 11, 2006 02:33 PM
LonS2k
40
Oct 11, 2006 10:17 AM
