Occassional Stumble Within 1st 5 minutes of Driving
Originally posted by Shvitz2k
happens to me all the time everymorning.......im not really worried about it........if it really bothers you change the map sensor....
I've always assumed this behavior is just part of the closed-loop engine controls designed to monitor and limit emissions. In the first couple minutes after a cold start, the cat is not up to temperature and the ECU is trying to monitor and adjust everything to minimize emissions while also warming up the engine (conflicting requirements).
I think short-term fuel trim may also be a factor, as I have occasionally noticed a stumble when restarting after a track session -- in that case, the engine's still warm (though the cat may have cooled a bit), but I'd just spent 20-30 minutes in VTEC.
Oddly enough, my 91 MR-2 did that when I had it. It did the same exact thing: right after start up, the engine would "stumble" for a fraction of a second, and then it would run just fine the next time I jumped on the gas. I never worried about it much, since it was not all the time.
If it bothers you that much, just have the dealer look at it. If they can't find anything wrong with it, it should be fine.
My car was running perfectly the first 43.000 miles, but now it is doing about the same thing you describe.
It is most pronounced when cold, but sometimes when it is hot I can feel it as well.
I have no idea where it came from though.
Crono0001
Jul 24, 2014 07:23 PM
