S2000 Body and Paint Body kits, paint, ding repair and related discussions
Paint damaged caused by overpolishing
Old 10-14-2018, 06:26 AM
rudyy's Avatar
Default Paint damaged caused by overpolishing
The overpolishing damaged the paint on the rear quarter. It is right at the edge next to the trunk gap. This is my first time doing detailing using the Porter Cable DA. A good lesson to learn on polishing the edge area.
So what is the proper way to fix it wihout repainting the whole panel? Can I just use some touch up paint and clear coat with 3000 grit wet sanding to blend with the existing paint?
Old 10-14-2018, 06:33 AM
rudyy's Avatar
Old 10-14-2018, 06:37 AM
Car Analogy's Avatar
Received 1,316 Likes on 994 Posts
There is a subforum for exterior/paint. You'll probably get more/better advice there...
Old 10-14-2018, 06:59 AM
zeroptzero's Avatar
Received 3,378 Likes on 2,454 Posts
careful application of touch up paint and it will hardly be visible. Small thin applications
Old 10-15-2018, 02:21 AM
rpg51's Avatar
This is what scares the crap out of me about using a machine on my car when I have zero experience using a machine. I must say I thought the DA was supposed to prevent this. Can you share a bit more about how it happened?
Old 10-15-2018, 04:29 AM
rudyy's Avatar
I opened up the trunk and polished the edge area at an angle...
Old 10-15-2018, 06:01 AM
rpg51's Avatar
Well, if I ever muster up the courage to use my DA at least I know now to avoid the edges of body panels. Thanks for sharing that. I could easily have done the exact same thing.
Old 10-15-2018, 09:11 AM
Panel edges PLUS any creases. Like the crease that runs along the top of the fenders and quarter panels. That line near the bottoms of the door and fenders.
Do those areas by hand.
99MCoupe (10-20-2018)
dfvs2k
07-28-2010 03:38 PM
Legal Bill
04-05-2009 04:00 PM
kent-k
09-21-2006 12:25 PM
Bruinlax
11-05-2001 11:23 AM
Quick Reply: Paint damaged caused by overpolishing
