Site Info Open forum for the discussion of the S2K International site and organization. If you like what we're doing, post it here. If you don't, post it here too. Get answers to site related questions.
How do I reset the "Maint Req" light?
Old Oct 10, 2009 | 04:21 PM
dammitjim's Avatar
Default How do I reset the "Maint Req" light?
The link in the S2000 Talk FAQ to fixing the maint req light is broken:
Here:
"Maintenance required light- This light is indicates 6,000 miles have accumulated on the odometer since it was last reset. The indicator blinks at 6K and will illuminate continuously after 7.5K.....indicating you should get the oil changed. If you self serve, reset the indicator as follows- https://www.s2ki.com/faqs/showfaq.php?threadid=17415
The S2000 Under the Hood FAQ has a good link
Here:
"How-To Clear a CEL / Clear the ECU / Clear Maintenance Required Light / ReLearn ECU"
- Could someone fix the link in S2k talk?
- Would it make sense to consolidate the FAQs into one? I think some of the newbs that read the stickies are only looking in one or the other.
Old Oct 12, 2009 | 01:45 PM
cthree's Avatar
Administrator
Fixed, thanks.
Hopefully I can get search to a point where faqs aren't entirely necessary. FAQs cover only a handful of the most common information which should be the easiest to find with search since there are so many topics about them.
It's still a work in progress.
Old Oct 14, 2009 | 08:55 PM
dammitjim's Avatar
Coolio.
FWIW I think the search here in alot of ways is easier to use than a typical vbulletin search. The one feature I wish it had was a search by post|thread toggle.
s2konroids
Oct 16, 2006 01:15 PM
SteveT
Jun 4, 2004 08:06 PM
HeNeSSeY
Sep 26, 2001 04:56 AM
Relson
Jul 30, 2001 04:10 AM
