South Florida Owners from South Florida
alignment specs
Old Dec 23, 2003 | 05:21 PM
mav's Avatar
mav
Default alignment specs
When I come back next week, I should (hopefully) have a few goodies waiting for my S from Santa. After I'm done with the installations, I need to have my S aligned. It will be lowered about 1.3"... Does anyone have any alignment specs they can give me? Josh? Alex?
I want a pretty aggressive alignment, thats good for street use and the occassional monthly autox, but I don't want to be burning through tires either. Also can someone recommend a good shop to do an alignment at? Somewhere that they will not damage my BBS wheels. Rick Case Honda? Miami Chassis?
Thanks in advance and happy holidays.
Old Dec 23, 2003 | 10:34 PM
LiQuiDiCe's Avatar
alex told me there is alighnment spec that they use in japan, i was planning on using the same thing when i lowered my car. i just have no idea where they are =P
Old Dec 25, 2003 | 02:03 PM
mav's Avatar
mav
Is this it?
I haven't heard of any specific alignment specs from Honda other than the OEM and this recommended spec coming from Honda UK. Supposely Honda UK got an S2000 and track tested it to come up with these new specs to combat British owner complaints about lack of steering input.
Old Dec 29, 2003 | 07:40 AM
jvils's Avatar
Hey Mav. Those specs are a bit more aggressive than US honda specs. I think the recommended is something like -.6 to -.8 front camber and -1 to -1.2 rear camber.
With wider rims and a lowered car, extra neg camber will help with rubbing. I just got mine set to:
Front: -1.7 camber, 5.8 degress caster (go to 6 if they can)
Rear: -2.4 camber
Zero toe-in front and rear. This is with S02 and a Saner Sway bar. When I get my Volks and Toyo RA-1's, I'm going to bump up the rear camber and add some rear toe-in (-2.4 camber was the max they could do without adding some toe-in).
Anyway, I'm hoping to get 5-7 track days, and up to 10,000 miles on the tires. You may want to go a bit less agressive, I've seen several people go with -1.5 front, and -2.5 rear, but you will see inside tire wear. You can always rotate side to side to extend life, but you have to re-mount the tires on the rims to do that.
hth, j
Old Dec 29, 2003 | 08:11 AM
Hunter's Avatar
SEX SEX SEX SEX!!!!!!
See it made it pat 3 posts!!!!
(dan is an asshole)
Old Dec 29, 2003 | 08:18 AM
LiQuiDiCe's Avatar
jeff = thread hijacker!
Old Dec 29, 2003 | 08:21 AM
Hunter's Avatar
By the way, I would like this spec also as Santa sorta showered me with a little more than I expected! (snicker)
(back to topic)
Old Dec 31, 2003 | 05:12 AM
CoralDoc's Avatar
I was using the following specs on Ruby, but she was on stock suspension.
Front Camber: -1.1 deg.
Rear Camber: -2.1 deg.
Front Toe: 0
Rear Toe In (total): 0.2 deg
Front Caster: 5.8 deg
Old Jan 9, 2004 | 01:20 PM
bigpurp's Avatar
mav, let us know who did your alignment, and if you're happy with it. I too need to get mine done soon, and would be interested in your review.
Old Jan 9, 2004 | 02:10 PM
Fyrestrike's Avatar
Front Toe: 0
If in the future, I lower the car about an inch...how would the alignment settings have to change? Is there a system of how to determine the proper alignment for a specific setup? Or is it just trial and error.
