South Florida Owners from South Florida
Getting valves adjusted
Old Mar 23, 2006 | 09:16 AM
LHP_Sailor1P's Avatar
Do I hear upcoming tech day????
Old Mar 23, 2006 | 09:24 AM
Jsmply's Avatar
CoralDoc said probably June/July
Old Mar 23, 2006 | 09:36 AM
Diablo99V's Avatar
Great! I might just go to help out.
Old Mar 23, 2006 | 10:10 AM
Sounds good should have my car back from BS then
Old Mar 23, 2006 | 06:11 PM
CoralDoc's Avatar
Yep, it will be at least a couple of months before I can host another tech day. But, I will host one!
So many tracks - so little time .
Old Mar 23, 2006 | 07:15 PM
Jsmply's Avatar
What is required to "host" a tech day, do we just need a spot for cars or do we need lifts? I might be able to host one in the summer sometime if any mechanically inclined people want to help, I can volunteer a big back yard and a BBQ, lol.
Regardless they inspected my valves today and said they were within spec. Louie told me he didn't know I wanted the retainers inspected so he kept the car again overnight and will check them out in the morning. After my experiance at the other Honda dealer, I want it done for peace of mind (I swear my car was taken for a joy ride, lol).
Old Mar 24, 2006 | 06:15 AM
Diablo99V's Avatar
^ I check my miles everytime Idrop my car off somewhere.
Old Mar 24, 2006 | 06:55 AM
jeffbrig's Avatar
If this is true, it would be the first out of all the cars we've done at CoralDoc's that didn't need something adjusted. We found that the valves tended to be near the loose end of the spec, and each car had 2-3 that were outside of the spec range. This was even the case with low-mileage cars like yours. I suspect you're dealing with a situation where someone did a cursory check and called it "good enough".
Old Mar 24, 2006 | 07:43 AM
Jsmply's Avatar
That may be true, I believe he said that they all measured .008. I haven't picked up the car yet, will ask again today for a report. They still have the car till this afternoon as I requested they inspect the retainers as well and they didn't do it the first time they had the valve cover off.
Old Mar 24, 2006 | 09:04 AM
jeffbrig's Avatar
That sounds weird to me. I suspect that he used a .008 feeler gauge and found it was a "go" on each valve. Keep in mind, Honda only recommends a valve adjustment at 105k miles, so in the service department's eyes, you're crazy for even asking them to open it up.
FYI,
Intake spec is .008-.010
Exhaust spec is .010-.012
At our tech days, we set intake and exhaust to .008 and .010, respectively to maximize valve lift and duration.
Either the previous owner adjusted the valves down to .008, or someone didn't do a very good job measuring them. If the exhaust valves are really at .008, they need to be adjusted, that's too tight.
(In case you can't tell, I don't generally trust other people to work on my car)
