Leaking water in-cabin from AC?
My passengers been complaining that they're feeling water on the floor and dripping from the dash - Car is under warranty so I'll just take it to Honda but what is the cause of this?
What about a leak in the top? Also you might check to see if your drain holes in the front of your car are clogged. This will cause the water drain to go inside the car on overflow. No lie this happened to a friend of mines convertible. They pulled out a pile of leaves and other debris!
Good luck!
Deiger
Good luck!
Deiger
I think it may actually be related to the A/C. Mine's dripped a couple drops of cold water on my leg on maybe three occasions - all were when I had the A/C on full blast for long periods of time. Maybe condensation forming somewhere and coming down?
The tubes run along the passenger side, so a small amount of condensation is to be expected. If it's a lot, though, it's time to take it in for service. There's a TSB for a crimped drain line...if you run the A/C a lot, the drain line backs up and dumps it on your feet instead of the pavement.
Originally posted by liquid_iq
Check out the TSB on this:
https://www.s2ki.com/user/content/view/full/287/
I saw him once at the airport in GA (way back shortly after wrestling was becoming a well-known spectator sport)...surprised the hell out of me. If memory serves, I think he owns a small ranch near Ocala.
