South Florida Owners from South Florida
Need brake help!
Old May 13, 2014 | 12:47 PM
gst19psi's Avatar
Default Need brake help!
So I bought new rotors and pads, but as I expected the brake rotor screws would not budge. I used PB blaster and impact screwdriver and nothing they didn't budge. So if anyone has any suggestion or wants to help let me know.
Old May 13, 2014 | 01:08 PM
slowd16's Avatar
I drilled the heads off mine when they were stuck.
Old May 13, 2014 | 01:39 PM
RENDERMAN's Avatar
try first option one...
http://www.4130-products.com/step/screw/index.htm
If it doesn't work try option two....borrow or buy this tool, hit it with a hammer and it turns automatically to loosen the screw (the professional way)
If neither way works then you're literally screwed lol follow slowd
Old May 13, 2014 | 04:06 PM
Ricky_Flowers_'s Avatar
Mike, if RENDERMAN's solution doesn't work (it should) take a drill and cut basically a big ass groove in the head to use with a large flathead screwdriver. I did this on all four of my rotors successfully.
Old May 13, 2014 | 05:00 PM
gst19psi's Avatar
Thanks guys. I'll try the ball peen hammer trick and then try the impact driver again. I just don't think this is going to work. Lol
Old May 13, 2014 | 05:02 PM
Dead Serious's Avatar
i broke the tip on my impact driver and they still didnt come loose.....just drill em.
Impact driver will only strip it more.
Old May 14, 2014 | 06:15 AM
M.A.R.C.'s Avatar
+1 for drilling them out. Had to do it on all my cars at one point or another
Old May 14, 2014 | 07:57 AM
gst19psi's Avatar
So I wasn't the only one to break the bit. Lol. If done right the impact won't strip the screw.
Old May 14, 2014 | 10:32 AM
LOL that is a big IF.
Kyushin
Dec 31, 2009 08:20 AM
craig2teg
Jul 29, 2008 08:35 AM
replicah
Jul 20, 2007 12:20 AM
nivag
Nov 29, 2005 06:44 AM
Mikey
May 19, 2002 08:46 AM
