South Florida Owners from South Florida
Valve adjustment
Old Aug 25, 2003 | 11:34 AM
F1s2000's Avatar
Default Valve adjustment
Has anyone had there valves adjusted? And by whom? I might do them might self or have one of the local dealers do it. Thanks.
Old Aug 25, 2003 | 02:47 PM
CoralDoc's Avatar
1) Yes
2) Me
It's not difficult, but it is tedious. I did my first adjustment at 23k miles and found 2 intake valves slightly out of spec (too much clearance). I set all intake valves to 0.008mm and all exhaust valves to 0.010mm; the low end of the specified range. I did a second adjustment at 49k miles and found that they hadn't changed much - 4 of 8 intake valves increased their clearance slightly, but were still within spec, and none of the 8 exhaust valves changed.
IMO, it's worth doing once the engine has settled in, but probably isn't worth repeating until you've reached higher mileage than me (unless you hear valve noise).
Old Aug 25, 2003 | 04:20 PM
F1s2000's Avatar
Thanks doc.
Old Aug 25, 2003 | 05:29 PM
SC-SUZUKA's Avatar
Alex, if your going to do this project I will not take it to a dealership, they might not do this job very well. If I was in your shoes, I'll call Darin {Pacific} or Stepahn {Car-tek} or Josh {CoralDoc} to help you out. Good luck.
Chris C.
kukudm
Jan 24, 2016 11:17 AM
CKit
Jan 27, 2007 10:23 AM
CoralDoc
South Florida
Jul 8, 2006 10:35 AM
amartin
Dec 22, 2003 01:14 AM
Gernby
Oct 25, 2002 11:25 AM
