aftermarket radio and s2000 antenna booster
after hooking up my Alpine radio in place of the oem radio I have noticed poor radio reception
Since I'm using the modifryadapterr for the dash buttons and not using the factory connector Irealizedd the antenna booster is not actually hooked up. ( I spliced into the oem wiring rather than buying the modifry connector adapter.
There is a yel/grn wire that comes from the oem antenna booster.
To what wire can I connect this to coming from the Alpine radio? Should it be spliced into the ign wire or can I use one of the unused radio wires such as the amp remote turn-on?
[img]carotman.no-ip.com:8888/personal_site/howto/pk2conversion/wiringprogress.jpg[/img]
I hacked everything up with a butter knife
I'm pretty sure the amp remote turn on from your deck can only handle 500mA or something along those lines. I'd use the ignition wire depending on the boosters power requirements. Worst case is you use a relay as well.
