Southern Ontario S2000 Owners Southern Ontario S2000 Owners forum including Toronto, Kitchener/Waterloo, Hamilton and surrounding area
Key Question
Old Aug 13, 2022 | 03:19 AM
jsullyboy's Avatar
Default Key Question
I normally use the remote to lock, unlock, and open the trunk. I tried the ignition key on the trunk the other day and it does not work. It doesn’t work on the glove box either. Do you need a second key for the trunk and glove box? Is this normal?
Old Aug 13, 2022 | 05:25 AM
Double_L's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
Are you trying to use the valet key to open the trunk and glove box? Try using your master key and should work.
Old Aug 13, 2022 | 11:47 AM
jsullyboy's Avatar
Trying to to use what I think is the master key. I will try the other key I have maybe it will work for all.
Old Aug 13, 2022 | 12:59 PM
Chuck S's Avatar
You're describing how the grey Valet key works. Regular keys are either black or a more fancy black/silver.
-- Chuck
Old Aug 15, 2022 | 05:04 PM
fernando.'s Avatar
Your vehicle may have had a new ignition cylinder installed at some point, which comes with new keys, and only the cylinder for the ignition was changed.
Does it work on the drivers door?
Old Aug 22, 2022 | 10:24 AM
jsullyboy's Avatar
The master key works in both doors and the glovebox. Just does not work in the trunk. Perhaps the trunk lid was replaced and they didn't swap the lock? Is there a way to rekey the lock?
Old Aug 22, 2022 | 11:21 AM
Chuck S's Avatar
If I understand correctly none of your keys will turn the trunk lock and open it. Looks like you can spend $60 and fix this yourself or check if a locksmith can just re-tumbler the existing lock for one the keys you currently have which is what I'd do rather than carry yet another key.
The key lock in the trunk lid is mechanical so if any keys turn in the lock the problem is the lock mechanism is disconnected from the trunk latch somehow. But as noted if the lock itself won't turn you need it replaced or re-keyed.
-- Chuck
Old Aug 22, 2022 | 12:09 PM
jsullyboy's Avatar
Thanks Chuck
mrmak
Apr 3, 2010 12:08 AM
crazydude
Dec 31, 2008 11:22 AM
Mark16q
Aug 3, 2004 05:22 AM
wanabe
Jan 1, 2001 09:46 AM
