What battery to get?
The OEM battery isn't anything particularly special as far as size and such. Its just a 51 series battery which is the same for most honda's. I think the only difference is the terminals are reversed, but there should be enough slack on the wires to go that extra couple inches.
Ill try to desulfate my battery, it may help
We have a ton of room in the battery area, you can likely fit a variety of sizes if needed.
I easily fit this smaller battery in there using the stock mounting bracket. Here's my 23 lb. cat vs. 17 lb. battery, you'd never expect a cat to weigh more than a car battery, lol. Cost considerations aside, this battery is a great balance between weight savings and performance, it still performs better than the stock battery.
zeroptzero you should invest in a trickle charger if you don't have one already and make sure if your car is sitting for more than a week to have that little guy charging. Also don't ever run any accessories without the car running, my radio didn't last 30 minutes when I had my Braille and that's what killed it.
Originally Posted by oooS2ooo' timestamp='1462042761' post='23953272
[quote name='CR EH' timestamp='1462034078' post='23953201']
[/quote]
A good electronic battery charger will de-sulphate as the first step in the charging process, I have the CTEK charger , but others do that too.
