Moddiction/ AB-Speed Catch cans/coolant overflows
#21
I can do a DIY on moving cruise control to the cross member if your interested. Takes less than 30min. No having to extend any wires or anything.
Heres a picture of where mine is at. If you need a write up on moving there i can do so. Basically I used 2 sided 3M molding tape and used 2 of the screws from the stock bracket to pinch the top part of the cross member. Been there over a yr and still holding strong. Wrapped a zip tie around it in case it did come off but never did have a problem with it. 3M 2 sided tape is some serious stuff if applied properly by cleaning the surfaces with alcohol and then heating the surfaces with a hair dryer or heat gun before applying the tape,
#23
Sponsor
Originally Posted by [email protected]
I really want one of these bad
Glad you are happy with it. Thank you!!
#28
Sponsor
