Evasive Motorsports Flash Pro/ Hondata Traction Control
Former Sponsor
Need a tune? Evasive offer Flash Pro and Tune Package. PM for more info or give us a call at 626-336-3400
Hondata FlashPro - US Honda S2000 2006 +
Our Price: $690.00
FREE NEXT DAY EXPRESS SHIPPING INCLUDED! (lower 48 states only)
NOTE: Orders placed after 12 Noon PST Friday, or during Saturday or Sunday, will be shipped out the following Monday. Orders shipped out Friday, will not be delivered until the following Monday as UPS does not have Saturday deliveries to most territories.
The FlashPro allows full user tuning and datalogging of drive by wire S2000s. It includes Windows based software called FlashProManager. The FlashPro connects from your laptop's USB port to your vehicles diagnostic port to provide 90 second programming with a variety of calibrations with extensive real time and stored datalogging capabilities.
FlashPro features:
- Programmable ECU interface.
- Connects via OBDII diagnostic port.
- USB 2.0 connection
- Works with Laptop or Desktop
- No ECU modification necessary.
- 90 second ECU programming time.
- 20 hours on board datalogging memory.
- FlashProManager Windows software.
- Check and clear diagnostic codes.
- Customizable laptop gauges.
- Readiness codes and smog check status.
- Dual calibration storage - upload from one of two calibrations stored in the FlashPro
2006+ S2000 tuning features:
- Ignition, fuel, idle speed, table editing.
- VTEC window.
- Rev and launch limiters.
- Map tracing & lambda overlay.
- Expanded fuel, ignition & cam angle tables for forced induction. - 4 bar MAP sensor support (40 psi).
- Support for larger injectors.
- Injector latency / dead time.
- Individual cylinder fuel & ignition trim.
Our Price: $795.00
Traction Control for your s300, KPro or FlashPro. Hondata Traction Control works by monitoring the ABS wheel speed sensors and reducing engine output when excessive wheel-spin is detected. A dash mountable switch allows the selection of different target slip rates, and software allows the system to be tuned for your specific vehicle setup.
- Fully programmable module with wheel speed sensor inputs and adjustable output to ECU.
- Works with inductive, active and hall effect sensors.
- On the fly adjustable target wheel slip.
- Live data monitoring.
- Twenty seconds of high resolution on board datalogging memory for setup and diagnostics.
- Wheel speed sensor error logging.
- Settings for target slip while cornering.
- PID control of output.
- Owner registration and password protection for security.
- Serial and CAN outputs for future expansion.
How does it work?
Simply put, the Traction Control commands the ECU to reduce power when the driven wheels are going faster than the un-driven wheels. On-the-fly adjustment of the target slip rate can be performed using a dash mounted switch.
Will this work on my vehicle?
If you have ABS, then the ABS sensors can be utilized. If your vehicle does not have ABS but is a model which supports ABS, then only the wheel speed sensors need to be installed. If you don't have ABS and no factory vehicle has wheel speed sensors, then you will need to add your own ABS wheel speed sensors.
Is this only for race cars?
No, it works very well on street cars.
Can you change tire sizes?
Yes, setting up for different sized tires is very easy.
Will this work on both front and rear wheel drive vehicles?
Yes, the principle behind the wheel slip calculation is exactly the same for front and rear wheel drive.
Does the Traction Control affect the ABS operation?
The Traction Control module has high impedance capacitively coupled wheel speed inputs which do not alter the signal to the ABS computer. However, if the ABS error light illuminates, or the ABS operation changes in any way, the vehicle should not be driven until the issue is identified and fixed.
Do I need an ABS computer, or just the wheel speed sensors?
Only the wheel speed sensors.
Do I need four wheel speed sensors?
Traction control will work with just one front and one rear speed sensor, but operation is better with four wheel speed sensors.
Will hall effect sensors work?
Yes, tie the negative side of the wheel speed sensor input to ground.
My car lifts one rear (FWD) / front (RWD) wheel off the ground when cornering. Will the traction control cope with this?
Yes, just set the speed determination method of that axle to 'fastest wheel'.
Free B-Series Iphone Case with purchase of Flashpro
Payment Information
Paypal
Paypal Address – Sales@Evasivemotorsports.com
Memo - #1 What you want to order #2 S2ki Member #3 Telephone number
We will only take confirmed paypal accounts with verified shipping addresses
Credit Card
Please give me a call at the office (626.336.3400) for any credit card transaction. The billing and shipping address has to be the same unless your shipping address is an alternative address filed with your credit card company
International
If you are an international customers we only take wire transfer as a form of payment. Please PM me for wire transfer information
8.75% California tax applies if you are in California.
Contact Information
Evasive Motorsports - 626.336.3400 - Dennis@Evasivemotorsports.com
Evasive Motorsports Website
Evasive Motorsports Blog
Our Price: $690.00
FlashPro features:
- VTEC window.
Our Price: $795.00
How does it work?
Payment Information
Paypal
Credit Card
International
Contact Information
