Ballade Sports Intake and Throttle Body Thread
Former Sponsor
Ballade Sports 00-05 Big Bore 70mm Throttle Body
PM for Pricing!!!
Ballade Sports is proud to introduce its 70mm Throttle Body for Honda S2000. Ballade Sports’s 70mm Throttle Body is designed for bolt-on horsepower and torque gains by maximizing engine airflow.PM for Pricing!!!
Ballade Sports Throttle Bodies are precision die-cast from high-quality materials and include features fully machined bores and idle adjustment screws for fine tuning. All throttle bodies undergo an extensive design and testing process to produce a throttle body that doesn't just provide more flow but retains smooth drivability and OEM throttle characteristics.
A larger throttle body is key to producing additional power throughout the power band on modified engines with increased airflow demands. Ballade Sports Throttle Bodies features a large, 70mm bore, which results in significant horsepower gains throughout the power band on NA and Forced Induction vehicles.
Factory TPS sensor and MAP sensor is required. (not included)
[media]https://www.youtube.com/watch?v=5jYInwRD32A[/media]
Ballade Sports 06-09 DBW ZDX Throttle Body Kit
PM for pricing!!!
PM for pricing!!!
We have produced a plug and play Throttle Body Setup for the 2006-2009. Utilizing the throttle body from the Acura ZDX/MDX J37 V6 we found Honda/Acura made a 80mm inlet to 70mm outlet into the intake manifold. Honda S2000 06+ models already use a 69mm intake plenum. Ballade Sports has constructed an Adapter Plate to fit the ZDX throttle body to the 06+ S2000 Intake Manifold. No boring or port matching necessary! 3 1/4" coupler will be needed to mate to an intake arm, or purchase with our Ballade Sports Intake Arm for easier and cleaner install. No need for transferring DBW servo/motors into the TB. Ch
Additional features:
Adapter features 70mm straight though bore.
OEM factory throttle body gaskets for S2k side and ZDX side included.
All Hardware for TB and Adapter included.
^(ZDX throttle body 80mm vs stock throttle body 64mm)
Ballade Sports Velocity Stack Intake Filter
Ballade Sports Velocity Stack S2000 Intake Air Filter - are constructed with ultra-strong molded pliable rubber flanges which absorb vibration and allow for secure attachment and can also be stretched for up to 1/16" (1.5mm) to fit in-between sizes. Mated with an Intake Velocity Stack is designed to optimize and maximize the entry of air flow entering the vehicle's induction system. The low velocity air flow taken through the air filter is turned into a smooth and high velocity intake charge. This is an upgrade and DIRECT FIT replacement for the OEM S2000 air filter unit. NO MODIFICATION to the OEM air box is required for fitment and increased air flow.
PM for pricing!
Ballade Sports Induction Intake Arm
The Ballade Sport Air Induction hose kit is designed to replace the original equipment rubber intake sleeve for the 00-09 Honda S2000, both in motorsport and fast road use. The original Equipment Manufacturer rubber sleeve hardens and cracks as time goes on, and other silicone intake hoses to not have provsions for the IAT sensor which are used in 06-09 S2000. Ballade Sports Silicone hose is life time warranty from wear related tears. Superb integrity and superior performance reduces the risk of component failure and enables higher temperatures and pressures to be maintained with complete confidence.
Available for both stock OEM throttle body and ZDX 80mm applications!
PM for pricing!
