Hard Dog S2000 Roll Bar
Former Sponsor
-Hard Dog S2000 Roll Bar-
GT Motoring is proud to offer the Hard Dog S2000 bar which is designed for the SCCA competitor that wants to maintain a dual purpose car for street and racing use.
The S2000 bar is compatible with plastic or glass rear window convertible tops and factory roll hoops. If factory roll hoops are removed, brackets are available to attach the stock shoulder harness guides.
Available in many configurations with removable and/or welded diagonal and/or harness bar. If the factory roll hoops and console are removed the harness bar can be installed at the height of the driver's choice.
Features:
-Full interior width
-Complete use of plastic or glass rear window soft tops
-Compatible with factory roll hoops
-Welded or removable main hoop diagonal brace and/or harness bar available
-Durable black powdercoat finish
-Constructed of highest quality 1.75" diam x .120" wall 1026 alloy drawn over mandrel tubing
-Laser cut 3/16" mounting and back-up plates
-Complete hardware kit w/ grade 8 bolts
Roll Bar Accessories:
-Stitched Vinyl or Leather Covers w/ our custom formed high density pad
-SFI approved high density and traditional foam padding
-Willans Safety Harnesses, for autocross and club racing
S2000 -
Item/Number - Description - Price
S2 S2000 Roll Bar - No Diagonal / No Harness Bar - Options Listed Below - $550.00
(Both Full Interior and Stripped Interior Versions Available)
Options Available
RD Removable Diagonal - Add $165.00
RH Removable Harness Bar - stock hoop compatible - Add $110.00
D Welded Diagonal - Add $55.00
2D Double Diagonals - not compatible with stock hoops - Add $110.00
H Welded Harness Bar - stock hoop compatible - Add $55.00
HL Welded Lowered Harness Bar - not compatible with stock hoops - Add $55.00
B Shoulder Harness Guide Brackets - stock roll hoops are removed and factory seat belts retained - Add $60.00
Bulkhead Brace Replacement Bar
CBAR Stock Seat Belt Reel Mounting Bar - replaces stock bulkhead brace for improved harness clearance - $175.00
Retrofit, Does Not require removal of roll bar to install
Stitched Covers w/ our Custom Formed High Density Padding
V Black Vinyl w/ custom formed padding - $85.00
L Black Leather w/ custom formed padding - $125.00
Hard Dog Custom Formed High Density Padding
CPAD Formed Pad Only - $45.00
Please email or PM me for price!!! Along with any questions or purchase requests. austin@gtmotoring.com
Please email or PM me for price !!! Along with any questions or purchase requests. austin@gtmotoring.com
Features:
S2000 -
Options Available
OK, so I have a couple questions! What is the weight of this in its most basic form? I notice in the first picture that one part of the interior plastic is missing. Can it be installed or will it not work?
Thanks
Thanks
Features:
S2000 -
Options Available
Please email or PM me for Special S2KI Pricing!!! Along with any questions or purchase requests. scott@gtmotoring.com
Features:
S2000 -
Options Available
The only ones that prevent you from putting all the interior back in are the ones with the welded lowered harness bar or the double diagonal design. Both of those won't let you put the factory roll hoops back in. Any other design will although it will require a lot of trimming.
Former Sponsor
That is correct. And to answer your question OG35Z the basic weight of the roll bar by itself is 30 lbs.
Former Sponsor
