replacement top
there is no glass window conversion.....you would have to replace the entire soft top.
the technique of unzipping/removing just the window and going with a glass replacement does not work and is not performed anywhere I have ever heard of.
I did not know if that was the procedure you were describing, I just wanted to get that out there in case you were trying to get that done. Just so you know it has been attempted and the prcoess is 100 % ineffective. the window will leak and the seal will never be the same once the OEM seal is broken. There is a zipper there and it can be opened but it was never engineered properly.
DesiS2k
May 22, 2012 11:24 AM
They did mine
