Texas - Central Texas S2000 Owners Central Texas S2000 Owners
Compression Test
Old Sep 1, 2008 | 09:39 AM
craig2teg's Avatar
Default Compression Test
Hey guys I want to get a compression test done. I was thinking about going to Fernandez or Gunn, but not sure how much they would charge. Any places around town yall have went to? And if so how much did they charge?
Old Sep 1, 2008 | 02:41 PM
frankys2k's Avatar
you can do it your self alot cheaper they sell the gauge at autozone. and search for post on s2k.com
Old Sep 1, 2008 | 02:50 PM
craig2teg's Avatar
Sounds like a good idea. I'll be heading to Auto Zone after work tonight. Is this a tool you can puchase or just rent?
Old Sep 1, 2008 | 06:08 PM
RavynX's Avatar
I purchased one for $25 at Autozone. They might have some for rent but it's really easy to do yourself.
Old Sep 2, 2008 | 04:08 PM
rickycrx's Avatar
I would recommend disabling the fuel injectors before doing a compression test. This can skew the numbers if you don't.
Probably pull the ECU fuse or find the fuse for the injectors before you do it.
I used to pull the ECU fuse on the CRXs when doing that before.
Old Sep 2, 2008 | 05:01 PM
frankys2k's Avatar
yeah you need to pull all that cuz its gonna squirt that fuel all up in there. i found out how do do it on a post here. so do some research i forgot it... sorry
Old Sep 2, 2008 | 09:29 PM
craig2teg's Avatar
Thanks for the info guys.
Old Sep 4, 2008 | 07:38 AM
svann's Avatar
The deluxe Auto Zone compression tester has a variety of different length attachments that thread into the sparkplug bores. If these are not tightened sufficiently or you overtighten the test plug you'll risk leaving the test plug in the engine. Definitely pull the ECU/injector and fuel pump fuses. To get a more accurate reading you can also attach your battery to another car, preferably running. Otherwise a low battery will crank the engine pretty slowly by the time you test the 4th cylinder. Post up your results.
gwnorth
Apr 28, 2018 07:38 PM
6262
Jun 9, 2014 04:37 AM
ack5252
Jul 11, 2013 06:22 AM
s2kneub
Apr 30, 2013 11:25 PM
hvd78
Jun 13, 2010 09:57 AM
