Need help w/radio/electrical problem...
Yesterday, while using a small air compressor plugged to the power outlet, the power failed to it. Also, the radio display is gone and it will not power up. The anti-theft light continues to flash and the CD eject works, just no radio. I checked the radio 15 amp fuse. It looked OK but I replaced it anyway. Still no radio, and of course the power outlet is dead. Any ideas to fix the problem?
[FONT=Courier]
GeneB[/FONT]
[FONT=Courier]
GeneB[/FONT]
Did you check the fuses inside and under the hood? There's a single fuse that controls pretty much everything. If that doesn't work disconnect your ground cable from your battery and reconnect it.
Thnks, Scott. I tried all that. Couldn't find any bad fuses and reconnecting the battery gnd didn't help. The ant-theft lite isn't flashing, but the CD eject button still works. Pwer outlet is inop. also. Very strange gremlin.
Gene
Gene
