Texas - North Texas S2000 Owners North Texas S2000 Owners Club
North Texas Club
will an ap2 Differential fit an ap1 ?
Old 11-25-2008, 04:50 AM
RockinDave's Avatar
Default will an ap2 Differential fit an ap1 ?
OK so my differential blew last night... will an ap2 Differential fit an ap1?... (04-08 fit an 00-03) and is there any benefit to doing so or should I just stick with an ap1?
Old 11-25-2008, 05:42 AM
mxt_77's Avatar
You should check the UTH forum, but I'm pretty sure the answer is yes.
Old 11-25-2008, 06:04 AM
CosmosMpower's Avatar
Yes but you need to change a flange or something like that.
Old 11-25-2008, 06:06 AM
RockinDave's Avatar
... What is the UTH Forum?
Old 11-25-2008, 06:08 AM
thatguyjosh's Avatar
Under The Hood
It's a subforum here at s2ki
Old 11-25-2008, 07:13 AM
RockinDave's Avatar
ok i just put a post on the uth thread maybe i can get some answers there
Old 11-25-2008, 07:17 AM
DFWs2k's Avatar
yes you need to change the output flange (ie, keep your ap1 output flange and put it on the ap2 diff), unless you are getting an ap2 transmission as well.
ap2 diff is a little stronger and the gearing is a little different, lots of people say f20c with ap2 gearing is a better match up than f20c with ap1 gearing.
Old 11-25-2008, 08:02 AM
JonBoy's Avatar
AP2 diff is indeed stronger but it has the same final drive (4.10) as the AP1.
The AP2 transmission is geared shorter and provides an excellent match to the AP1 motor as it boosts torque (mechanically) to the wheels while still allowing for that glorious redline.
Old 11-25-2008, 08:04 AM
mxt_77's Avatar
Actually, by "check" I meant "search".
I did a search on "diff swap" in the "UTH:Technical" forum and this was the 3rd result:
04 dif swap into 00-03
I think it has all the answers you need.
Old 11-25-2008, 11:20 AM
RockinDave's Avatar
thanks guys... I just went back with an ap1 diff. I didn't feel comfortable with a maybe it will maybe it wont work answer for my daily driver! good luck to those who try it out!
Quick Reply: will an ap2 Differential fit an ap1 ?
