ABS Light on
Old Sep 17, 2012 | 02:45 PM
MB's Avatar
MB
Member
Sounds like something degrading rather than the normal gap issue, but given the recent sensor change I'd guess it's a gremlin under there!
I'd try and get the code Si. Last time I had an EPS one, my dealer did a quick plug in for a small fee. If not most car tuning places or backstreet garages have code readers.
Old Sep 18, 2012 | 01:04 AM
richmc's Avatar
Originally Posted by Si2k
Wankers!
Torrets?
Old Sep 18, 2012 | 07:50 AM
Si2k's Avatar
Got a Snapon code reader on it.
Front Right open circuit and Front right no signal. I guess a wire has broken then?
Anyone got a spare wheel speed sensor
Old Sep 18, 2012 | 08:48 AM
MB's Avatar
MB
Member
Think my spare ones are from the rear Si, but will check!
Old Sep 22, 2012 | 08:28 AM
Si2k's Avatar
Replaced sensor and went for a 2 mile drive. Light still on :s
Old Sep 22, 2012 | 09:44 AM
Si2k's Avatar
I also had a low voltage error code when the sensor was flagged as a problem
I've checked the earths and unplugged both the ABS unit and removed the power fuse. Still the light is on.
Will try and get the code read again but I'm a bit stumped now as to what is the problem! The light stays on constantly even after unplugging it for ages.
Old Sep 22, 2012 | 09:53 AM
F3 ANG's Avatar
When you get the code reader again erase the codes, if it's still there then go into data and see if it's reading the sensors when you are moving, have you checked the ohms reading on the sensor,, you will get a low voltage error if the battery has gone flat or you have pulled the fuse
Old Sep 23, 2012 | 03:52 AM
Si2k's Avatar
Not used multimeter on it. Will try a spare battery on it I think
Old Sep 23, 2012 | 03:58 AM
s2konroids's Avatar
A multimeter is a must mate now.
Old Sep 23, 2012 | 04:11 AM
Si2k's Avatar
I think it's no longer a sensor issue and have been reading about the pre start checks the system does. Plus I have no idea where I hav put it
