Passenger floor wet
Old 02-13-2018, 06:07 AM
nomadicS2k's Avatar
Default Passenger floor wet
I need some help! My passenger floor is wet, right where the seat sits. The front of the well is dry. The carpet behind the seat on the rear bulkhead is dry. The roof drains are clear and draining. The seat is dry.
I have tried pouring water from a watering can over the roof and it didn't seem to get any wetter...
Thoughts?
Old 02-13-2018, 06:09 AM
nomadicS2k's Avatar
Found this for starters....link!
Old 02-13-2018, 06:13 AM
Melach22's Avatar
Had this same problem only on passenger side. Mine is from the weather strip seals on the passenger door. It won't immediately leak but takes time to fill up the track. Probably just need a new weather stripping over the window. Mine's been garaged for winter, just got to get it done lol. You can check to see that the fitment with the window is secure. Hope this helps
Old 02-13-2018, 07:08 AM
Nottm_S2's Avatar
Your passenger wet themselves?
Sounds like a winda leak
Old 02-13-2018, 01:55 PM
Melach22's Avatar
Old 02-13-2018, 02:00 PM
Melach22's Avatar
What's a winda leak?
Old 02-15-2018, 12:23 PM
nomadicS2k's Avatar
Winda!? lol - I did try with the watering can to no avail - will recheck the roof seal and check the door seals. Will also check the AC hose in the passenger foot well.
Old 02-15-2018, 09:47 PM
BenRNBP's Avatar
Have you had the window regulator / door panel off ? A leak at the seal between the door and the plastic sheet ( all that white gungy stuff) might explain this
cthree
S2000 Service Bulletins (TSB)
03-10-2014 08:17 PM
razorsharp192
07-24-2011 11:14 PM
ian_6301
03-04-2009 11:30 PM
Stanley
10-23-2005 06:26 PM
dlofneps2k
08-12-2005 03:42 PM
Quick Reply: Passenger floor wet
