After VTEC Tapping noise
Old May 30, 2002 | 04:38 AM
Pwantwan's Avatar
Default After VTEC Tapping noise
Just thought I'd post this:
I was out for a drive the other day hit 7000rpm in second then went upto 7000 in third then let the car run down to 4100rpm - I noticed a ticking/tapping sound comin from the center dash towards the engine slightly on the passengers side which was quite worrying as it just wasn't normal! I then checked the oil three times and behold my oil level was low (It was filling up 2 out of the 5 diamonds), I went and topped up the Oil at Honda and I then repeated the process and the noise has gone (let's hope it stays gone!). Thought I'd post this incase anyone else ever experiences it.
Should I assume that if 4 out of 5 Diamonds are not filled on the stick then don't vtec and get it filled?
Cheers,
Pt.
PS. I could mention all the good things about this car but I'd run out of words to use in the dictionary.
Old May 30, 2002 | 04:42 AM
Tifosi Red's Avatar
Yes, I've noticed a marked increase in tickover engine noise when my oil level starts to decline, topping up sorts it out though - suprising that a couple of hundred ml of oil can make such a difference isn't it?
FWIW I try and keep my oil level on MAX i.e. all diamonds filled, after all this is the way the car comes out of the factory
Tif
L8BRAKN
Aug 3, 2017 09:11 AM
JayJones
May 18, 2015 08:12 PM
tehsu
Dec 14, 2009 11:53 PM
GaryB
Jan 22, 2009 01:35 PM
Jagga_s2k
Apr 16, 2008 08:03 AM
