Alarm Fob Programming
Old Feb 17, 2009 | 08:43 AM
DaDoRonRon's Avatar
Default Alarm Fob Programming
I know this has been looked at many times, but I cannot get things to work. I have a new Hamilton and Palmer supplied fob, and I need to put the system into learning mode. The manual says, disarm the system turn ignition on-off-on-off-on and press existing fob 3 times. The led and indicators should then show we are ready to go. Trouble is this does not seem to work. Is there a knack to this?
Old Feb 17, 2009 | 08:53 AM
s2konroids's Avatar
Sorry mate i tried the instructions and couldnt get it to work either
Honda did it in the end for free.
Old Feb 17, 2009 | 09:13 AM
tomkbucks's Avatar
Hamilton and Palmer should supply the instructions ? they seemed very helpfull to me give them a call the designed the alarm !
Old Feb 17, 2009 | 09:16 AM
DaDoRonRon's Avatar
Actually they did send me a fresh set, but just the same as I already have.
Old Feb 17, 2009 | 09:18 AM
tomkbucks's Avatar
id talk to them , im sure they will be able to help , ive not done mine yet, will do it at the weekend,
Old Feb 17, 2009 | 10:13 AM
FunBox's Avatar
You may need a 'red fob' if its one of the originals. Without this you have to remove the board send it to Hamilton and Palmer and get it recoded and a new red fob. About
Old Feb 17, 2009 | 10:46 AM
tomkbucks's Avatar
how old is the car ? does it have a red led on the plip ? is not then it will need a red key!
Old Feb 17, 2009 | 11:14 AM
dennohue's Avatar
To the OP.
Are you using an existing (i.e. already programmed) handset - as you have described - to get to the 'learning' mode?
Old Feb 17, 2009 | 11:25 AM
s2konroids's Avatar
My fob has the led on and I still couldnt get it to work
Old Feb 17, 2009 | 12:18 PM
RISLAR's Avatar
Try the programme sheet in the faq section, it worked on a few of mine
