ALARM PROBLEM
Old Oct 18, 2013 | 09:19 PM
s2k tony's Avatar
Default ALARM PROBLEM
I unlocked my car this morning and the alarm started going off so I locked it again but it was still going off. the alarm goes off for about 7 seconds then stops for roughly the same amount of time then goes off again. When the alarm stopped I started the engine but it still went off with the engine running. What can I do to stop the alarm going off? Its a 2004 model.
Old Oct 18, 2013 | 11:19 PM
Bassoctopus's Avatar
On my 2000 model the alarm going off was a sign that the car battery was in its way out. Different alarm in 2004 cars so probably not much help for you.
Old Oct 18, 2013 | 11:32 PM
s2k tony's Avatar
I was thinking it could be the battery but there have been no signs that its on its way out. I might just buy a new battery and see if its works.
Thanks
Old Oct 19, 2013 | 12:12 AM
Kwik fit or someone similar should be able to test yours
Old Oct 19, 2013 | 12:35 AM
chrispayze's Avatar
On my 04, it did that if I unlocked it (didn't open a door), popped the boot and then shut the boot just as it automatically re-armed. It happened to me a few times over the years.
Old Oct 19, 2013 | 01:12 PM
s2k tony's Avatar
I got my battery tested and the battery is fine so it must be the factory alarm that's playing up.
Old Oct 19, 2013 | 10:48 PM
BenRNBP's Avatar
I had this after I arrived at work a few months back, opening and closing he bonnet seemed to do the trick ( I'd tried doors and boot first and that didn't seem to sort it out)
Old Oct 19, 2013 | 11:40 PM
Bandit_287's Avatar
Mine did that about four years ago. I think the alarm module got confused when I opened/closed the drivers door and boot at the same time. Can't remember how I did that though. The alarm went nuts for about 5 minutes resetting itself and the siren wouldn't shut up whatever I did. It eventually sorted itself out though and has been fine ever since.
Old Oct 20, 2013 | 07:27 AM
Nick Graves's Avatar
That used to happen on the Prelude - the bonnet sensor was corroded to fuck & kept shorting & so I rebuilt it with a lot of solder.
I could drive along with the alarm going off.
Changing the battery seemed to make the driver's door lock actuator work again.
All the faults were very rare/intermittent, so it was difficult to be 100% sure.
senninha1994
Sep 8, 2009 10:43 AM
Duracell
Jul 4, 2008 06:45 AM
Stiggywig
Feb 18, 2008 12:31 PM
Ant09
Oct 8, 2006 09:48 AM
RichT2000
Feb 1, 2005 05:04 AM
