Alarm problem
Old Jun 19, 2005 | 02:14 PM
DELLROY's Avatar
Default Alarm problem
I have the standard two button honda alarm, went to lock car using remote and nothing happend presseng the other button to unlock and you can hear the solinoid in the door working but indicators dont flash. you can lock the door with key then press the remote and it will unlock but still wont flash indicators. have changed battery in both remotes, but still no joy car starts and runs. HELP.
Old Jun 20, 2005 | 07:27 AM
AdrianEagle's Avatar
Garage - Alarm diagnostic check!
Old Jun 20, 2005 | 09:49 AM
Shiskine's Avatar
Your plipper indicates you have the alarm/immobiliser that was fitted when the car got to the UK (as opposed to factory fitted). Work was carried out on behalf of Honda UK by Hamilton & Palmer.
AquilaEagle and I (and I believe others) have had problems with the immobiliser circuit playing up (in our case not disarming the immobliser), apparently due to a defective install. This should be repaired under warranty by your dealer (assuming it's the same problem).
S2K_Dallas
May 13, 2014 02:37 PM
Nickamsweet
Jan 15, 2011 06:56 AM
S2Krazy_uk
May 25, 2008 12:15 AM
s2000_nur
Apr 18, 2005 03:34 AM
Dracoro
Nov 7, 2003 04:18 AM
